0 members (),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Once again hello to everyone. Does anyone have any idea why the dash lights come on when I apply my brake pedal? This truck is "home" wired, the way I bought it and I've got everything else right but this one has me fooled. By the way, I installed a cut-off switch right away just in case something happened. Thanks for reading. Any help will be wonderful. Steven | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Hi Steven,
My truck was doing exactly the same thing and it was home wired also. I couldn't trace it down so I placed a zenor diode on each tail light wire to resolve the issue. I plan to rewire it this summer, but it was a quick fix.
Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | My guess is bad grounds at the tail light housings, and/or may need a ground strap between bed and frame. | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Thanks fellers, I'll try both ideas. Steven | | | | | Joined: Oct 2007 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 63 | had a similar problem before where the tail light circuit is powered up on the application of the brakes . problem faulty tail light with a short between brake and tail sending 12v back into the tail light / dash light circuit. fix on hotrod with custom lights was to install diode to stop feedback easier than fixing custom lights. That's where I would start at the tail lights isolate one at a time to figure which one it is. Tail lights should be the only place where these two cicuits brakes and tail lights are close together | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | "...with a short between brake and tail sending 12v back into the tail light ..."
There is not a "short" between brake and tail light. The filaments are connected to a common ground terminal. If the bulb is not properly grounded the 12V travels across the tail light filament seeking a ground, which in your case apparently it found it after traveling to the switch and the dash light circuit. | | |
