Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (TUTS 59), 55 guests, and 3 robots.
Topics128,009
Posts1,055,295
Members48,419
#639956 04/22/2010 7:03 PM
Once again hello to everyone. Does anyone have any idea why the dash lights come on when I apply my brake pedal? This truck is "home" wired, the way I bought it and I've got everything else right but this one has me fooled. By the way, I installed a cut-off switch right away just in case something happened. Thanks for reading. Any help will be wonderful. Steven
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
Red 49 Truck #639959 04/22/2010 7:10 PM
Hi Steven,
My truck was doing exactly the same thing and it was home wired also. I couldn't trace it down so I placed a zenor diode on each tail light wire to resolve the issue. I plan to rewire it this summer, but it was a quick fix.
Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
di1953gmc #639973 04/22/2010 8:08 PM
My guess is bad grounds at the tail light housings, and/or may need a ground strap between bed and frame.
waldo53 #639986 04/22/2010 8:49 PM
Thanks fellers, I'll try both ideas. Steven
Red 49 Truck #640421 04/24/2010 8:28 AM
U
U Offline
had a similar problem before where the tail light circuit is powered up on the application of the brakes . problem faulty tail light with a short between brake and tail sending 12v back into the tail light / dash light circuit. fix on hotrod with custom lights was to install diode to stop feedback easier than fixing custom lights. That's where I would start at the tail lights isolate one at a time to figure which one it is. Tail lights should be the only place where these two cicuits brakes and tail lights are close together
usa050aus #640476 04/24/2010 4:14 PM
"...with a short between brake and tail sending 12v back into the tail light ..."
There is not a "short" between brake and tail light. The filaments are connected to a common ground terminal. If the bulb is not properly grounded the 12V travels across the tail light filament seeking a ground, which in your case apparently it found it after traveling to the switch and the dash light circuit.
