3 members (NH46COE, Hotrod Lincoln, 1 invisible), 111 guests, and 8 robots.
Topics128,077
Posts1,056,031
Members48,433
#63964 08/07/2006 3:56 PM
Apprentice
Apprentice
Ok, so I found a running 235 finally. I made an offer and it was accepted and now want to order a offy or fenton intake. But both offy and fentons say they are good for 1955 to 1962. What changed in '63? Am I stuck with the stock intake? Any help on what might have changed from '62 to '63 and advice on what I can use??
#63965 08/07/2006 4:33 PM
Apprentice
Apprentice
Its the original motor in a 1963 halfton pickup according to the owner and he knows his stovebolts. I havent pulled numbers in it. Were can I run the numbers if I did have them?
#63966 08/07/2006 6:17 PM
i thought 62 was the last year that chevy used the 235 in the 1/2 ton trucks?? but if it is a 235 it will be the same set up as a 62 in regards to the intake and exhaust manifold. you will have to do a little grinding to make them fit. lots of info in the search section.
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#63967 08/07/2006 8:17 PM
1963 will be a 230. (unless it is four wheel drive) Completly different engine.
My Blog
#63968 08/08/2006 12:55 AM
Pre'68 Dave it right.
Turns out the owner doesn't know his stovebolts as well as you/he thought.
#63969 08/08/2006 1:57 AM
Per some old articles there were some 63 235s. Where is the distributor, in the center or closer to the front?????
1946 1/2-Ton Chevy
#63970 08/08/2006 3:29 AM
Hum...
62' was the last year for the 235. Full oiler, 848 head.
Check with Inliners.com for sure. Run your casting number from there site. That will zero it in.
Just finished the extremely lot of grinding on the Fentons. Not at all happy with the quality. Wish now I would have gone with another brand name.
And you'll have to grind clearance into your undersides of your Offys as well. Check with your supplier is they have replaced the zinc plugs and rewelded with aluminum.
Then if you put smaller bore carbs on top with flange hole spacing that is less, you'll have to have those holes heliarced (sp) milled flat and re-taped for what you have. $$$ frown
#63971 08/08/2006 3:53 AM
I've always heard that 62 was the last year for a 235. I also heard that the 261 was available in 63 on 4wds and burbs. But everything I've heard hasn't been true. Looking forward to finding out what it is.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#63972 08/08/2006 8:04 PM
'62 was the last year for 235 in the North American market, they were used up to the mid '70s in the South American market in vehicles manufanctured by GM do Brazil. They were also used by Toyota in the early Land Cruisers. To my knowlege, they stopped the 261 at the same time. I can't say for sure on 4x4's, but my shop teacher had a '61 3/4 ton with a 261 that was factory installed, so it may be possible.
Bill Burmeister
#63973 08/08/2006 10:16 PM
Patrick sells both the 216 and 235 Offy intakes. If you want to use 216 carbs you should get the 216 intake and machine the ports for 235 alignment rings. If your truck is planned for a driver I believe this is the best way to go anyway so you'll have more vacuum for decent low RPM operation.
I got fooled on ebay and ended up with a pair of repro Fentons and am astounded with their truly wonderful quality. Very heavy-duty and very good casting quality as well. I thought Patrick had an exclusive license to make them. Is there a backyard casting operation going on somewhere?
Mike Barnes
1950 GMC 1-ton pickup
#63974 08/09/2006 3:17 AM
the set I got from patrick looked pretty well made too. Still haven't got them on my jimmy yet!
#63975 08/09/2006 6:06 AM
Apprentice
Apprentice
ok, so it has six bolts holding down the valve cover and the distributor is almost at the front of the motor? I couldn't pull the numbers on the block. so does anybody know what it is based on that info???
#63976 08/09/2006 4:24 PM
NOT 235
My Blog
#63977 08/09/2006 4:50 PM
It can be a 194, 230, 250, or 292
My Blog
#63978 08/09/2006 5:43 PM
I don't know these later engines but the head casting number would be easy to see and might provide a clue if you run the numbers.
Mike Barnes
#63979 08/09/2006 8:36 PM
Again, pre68'Dave is right.
No need to look up numbers unless you care what it is, cause it sure ain't a 235.
#63980 08/09/2006 9:04 PM
Apprentice
Apprentice
Is it worth using since its not a 235? Can I get aftermarket parts for the other motors mentioned?
#63981 08/09/2006 9:33 PM
Anonymous
Unregistered
Anonymous
Unregistered
I think LMC Truck sells stuff for 230's
#63982 08/10/2006 6:32 AM
What do you plan on putting this engine in?
The later sixes are not an easy replacement for the 216 or 235.
My Blog
#63983 08/10/2006 6:54 PM
The later engine is actually a better engine to start with if you are wanting to modify it for better performance. Lots of performance parts are available for them and the head breaths much better than the old 235/261. I like them both and run them both but if you already have the late model engine I would certainly stay with it.
#63984 08/10/2006 6:56 PM
Apprentice
Apprentice
I am not looking for performance really. I just wanna run a straight six that I can put a two or three carb setup and a split header on.
#63985 08/10/2006 7:18 PM
brian - you might want to consider splitting the existing ehaust manifold to create your duel exhaust unless you are in to being a "purest". they sound about the same and most, notice i did say most, people cannot tell a big difference in perfomance on a daily driver - back and forth to work etc. with good welding skills you can do your own or kansas customs appears to be doing a real good job in this area. i have been told that the offy intake will bolt up to the original with less "grinding" and you do not have to come up with an additional heat source for the dual carb system. split manifolds are cheaper than fentons but then again it all comes down to what you want to do with your truck and how you are going to use it.
#63986 08/10/2006 7:35 PM
Apprentice
Apprentice
I guess I need to clarify. I want this to be a daily driver. I am not married to split headers I just want the old school rat rod straight six sound. This truck is being built as a rat rod with as few modern upgrades as possible.
