0 members (), 162 guests, and 4 robots.
Topics128,089
Posts1,056,139
Members48,435
#639103 04/19/2010 9:17 PM
Tell me if I am wrong on this but after removing the fenders bed skirt panels and tail lights all I need to do to lift off the bed is remove the 6 long bolts. Or is attached elsewhere?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
That should do it, unless some Einstein welded it on, like mine was.
Is the front panel not bolted to a crossmember?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
As I recall the front panel is only bolted to the side panels.
You are correct. there is a cross tie right behind the front panel that two of the bolts to the frame is located in.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Fried Green I don't quite understand your answer. If all 6 long bolts are removed would the bed lift off?
If I recall being under my truck there were a few horizontal front to rear bolts on that front panel which were bolted to a cross member.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Yes it will lift off when the six bolts through the frame are removed. I was just trying to point out that two of those are in the cross sill very close to the front panel.. As I re-read it I just contributed to the confusion, sorry.
1953 Chevrolet 3600
okay. no problem. thank you.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
On my 55.2 if I only remove the 6 long bolts, the cross members would be lifted off the frame as well because some of the strip bolts connect to the cross member. The front panel is also bolted to the strips as well.
Just put my bed back together last weekend so it is all fresh in my memory.
