6 members (Otto Skorzeny, MikeE, Hotrod Lincoln, ShopRag, TooMany2count, J Lucas), 32 guests, and 2 robots.
Topics128,036
Posts1,055,450
Members48,422
#63889 08/04/2006 3:35 PM
I just bought a 66 with a 350 the previous owner threw in a pair of Mickey Thompson aluminum valve covers, The 350 has the stock covers. He said he left on the stock covers because they are less likely to leak.
This is my first 350 so I was wondering if anyone has experience with this issue. If I change over to the Mickey valve covers will it just be for looks and possible leaking problems.
If it aint broke don’t fix it? Did I just answer my own question?
#63890 08/04/2006 3:45 PM
Billybolt,
This theory seems backwards to me. I would have thought the cast aluminum cover, being rigid and machined true, would be prone to leak less.
Stock stamped steel valve covers usually become tweaked from overtightening and will leak if not massaged and flattened before installing the gasket.
Stuart
#63891 08/04/2006 4:10 PM
I was kind of thinking the same thing since the Aluminums are more rigid.
#63892 08/07/2006 8:08 AM
And with cast aluminum covers,you don't need to tighten 'em as tight for 'em to seal.
Sounds to me like he didn't use the M/T covers cuz the steel ones weren't leaking,so why invite trouble-just don't ever remove 'em...
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
