0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63889 08/04/2006 3:35 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | I just bought a 66 with a 350 the previous owner threw in a pair of Mickey Thompson aluminum valve covers, The 350 has the stock covers. He said he left on the stock covers because they are less likely to leak.
This is my first 350 so I was wondering if anyone has experience with this issue. If I change over to the Mickey valve covers will it just be for looks and possible leaking problems.
If it aint broke don’t fix it? Did I just answer my own question? | | |
#63890 08/04/2006 3:45 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Billybolt,
This theory seems backwards to me. I would have thought the cast aluminum cover, being rigid and machined true, would be prone to leak less.
Stock stamped steel valve covers usually become tweaked from overtightening and will leak if not massaged and flattened before installing the gasket.
Stuart | | |
#63891 08/04/2006 4:10 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | I was kind of thinking the same thing since the Aluminums are more rigid. | | |
#63892 08/07/2006 8:08 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | And with cast aluminum covers,you don't need to tighten 'em as tight for 'em to seal. Sounds to me like he didn't use the M/T covers cuz the steel ones weren't leaking,so why invite trouble-just don't ever remove 'em... Speed | | |
