4 members (Gdads51, Otto Skorzeny, Hanks custodian, 32Fordpuchoptop), 167 guests, and 2 robots.
Topics128,047
Posts1,055,533
Members48,424
#6382 01/30/2005 2:10 AM
The local U-pull-it has a 78 Ford w/300& 3 speed OD. Trans has a squarish bolt-on top. Would this be a good choice for a 64 or is the bolt pattern different? Would the Chevy spit it back out because its a Ford part? Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#6383 01/30/2005 3:29 AM
It won't bolt up to a Chevy bellhousing. The bolt pattern is completely different, and I don't think it can be adapted. You'd also have to run a Ford clutch plate to match up to the input spline, with a Chevy pressure plate, and I doubt if they would be compatible without a lot of machining, if at all. Chevy had some OD trannies, but they were pretty scarce.
#6384 01/30/2005 4:14 AM
You can make it fit.....it's hell for strong.....the ratios suck!!!
Don't tow in O/D
#6385 01/30/2005 8:24 AM
Chevy did make a 4 speed truck transmission that would fit jam up in your '64. It's a 3 speed with 4th gear being overdrive (and it's been talked about quite a few times in the past on the bolt).
It's called a New Process A833 transmission and the GM RPO code is "MY6". Not the best ratios, probably not as strong as the Super T10 or the heavier duty 4 speed Muncies, but a pretty good box.
The .73 overdrive makes for nice cruising on the interstates. I have one in my '66 shortbed stepside and it was a bolt in replacement for the old column shift 3 speed.
-ftyler
#6386 01/30/2005 12:48 PM
That Ford OD is a redesign of the top loader muscle car 4 spd,a rugged unit.Yes, the gear ratios suck,but no worse than a typical 3spd with a planatary OD unit.
I've seen Ford tranny's in Chevy's using a Lakewood steel bellhousing and a custom pilot bearing.Advance adapter might have something too.Shorten the driveshaft,change the yoke,maybe a custom speedo cable.
#6387 01/30/2005 4:02 PM
I thought the bolt pattern looked diff, the Ford has a removeable floor pan so it was easy to look at but I had no tape measure. With the rear engine mounting on the bell,I'll keep looking for the GM OD. Brian
#6388 01/30/2005 7:17 PM
My High Tech adapter is a piece of 3/16 plate....bored the bell housing for the F@@d
