1 members (NJC),
138
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The local U-pull-it has a 78 Ford w/300& 3 speed OD. Trans has a squarish bolt-on top. Would this be a good choice for a 64 or is the bolt pattern different? Would the Chevy spit it back out because its a Ford part? Brian | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | It won't bolt up to a Chevy bellhousing. The bolt pattern is completely different, and I don't think it can be adapted. You'd also have to run a Ford clutch plate to match up to the input spline, with a Chevy pressure plate, and I doubt if they would be compatible without a lot of machining, if at all. Chevy had some OD trannies, but they were pretty scarce. Jerry
| | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | You can make it fit.....it's hell for strong.....the ratios suck!!!
Don't tow in O/D | | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Chevy did make a 4 speed truck transmission that would fit jam up in your '64. It's a 3 speed with 4th gear being overdrive (and it's been talked about quite a few times in the past on the bolt).
It's called a New Process A833 transmission and the GM RPO code is "MY6". Not the best ratios, probably not as strong as the Super T10 or the heavier duty 4 speed Muncies, but a pretty good box.
The .73 overdrive makes for nice cruising on the interstates. I have one in my '66 shortbed stepside and it was a bolt in replacement for the old column shift 3 speed.
-ftyler | | |
#6386 01/30/2005 12:48 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | That Ford OD is a redesign of the top loader muscle car 4 spd,a rugged unit.Yes, the gear ratios suck,but no worse than a typical 3spd with a planatary OD unit. I've seen Ford tranny's in Chevy's using a Lakewood steel bellhousing and a custom pilot bearing.Advance adapter might have something too.Shorten the driveshaft,change the yoke,maybe a custom speedo cable. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I thought the bolt pattern looked diff, the Ford has a removeable floor pan so it was easy to look at but I had no tape measure. With the rear engine mounting on the bell,I'll keep looking for the GM OD. Brian | | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | My High Tech adapter is a piece of 3/16 plate....bored the bell housing for the F@@d | | |
