1 members (stlcardinalsguy),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 28 New Guy | | New Guy Joined: Jul 2008 Posts: 28 | Maybe someone can enlighten me. I have a 55.1 3100 that has a bent front axle tie rod. I looked in LMC truck for a new one and they want $329 + shipping for it. The second generation 55 would only run me $29.95 + shipping. In the picture they look like the same thing. What is the $300 difference? | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | As your probably aware the 2nd series in 1955 was a totally new model, i.e., the TF. I can't say specifically what the differences are in the two front suspensions but I do know that you cannot make a judgment based on an catalog illustration. Also I think the 29.95 each is for the ends only and not the entire tie rod [censored]'y. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Bent tie rods are not to unusual on the AD trucks. They are right out there in the open where they can be bent by a snow bank, stump or misplaced jack You can always straighten it. I used my hydralic press to straighten mine, takes only a few minutes to true it up. I made a set of clamps that sit flat on the press frame and keep the rod from turning. http://www.pbase.com/dennygraham/image/121617855 Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | The one on my '58 was bent as well. My neighbor and I took it to his anvil with a sledge and trued it up enough to slide a 3/4" pipe over it. (I know opinions will come out about what I did next.) I then welded the pipe over the rod for added strength. She solid as can be now, won't bend near as easily and it hasn't failed now for the 2 years its been on there. I work at a camp in the summer and the roads are rough. She has held up to that abuse.
58' 3200 235 3-speed/OD
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | All tie rods from 1937 through 1954 pickups are the same. They will all interchange. There should be several at any large wrecking yard near you. If not, Chev's of the 40's stocks them.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Mar 2010 Posts: 26 New Guy | | New Guy Joined: Mar 2010 Posts: 26 | i just bought one for my 51 from classic parts for like $36. i went through the same thing at lmc and they couldnt tell me why the big differenc in price, but classic was the way to go | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No welding on steering Part!! Hope your luck doesn't run out. Denny Graham Sandwich, IL
