4 members (38Kiwi, UtahYork, dt235sd, Hotrod Lincoln), 123 guests, and 2 robots.
Topics128,196
Posts1,057,390
Members48,471
hey guys, its been quite some time since i've posted as i've been at school in charlotte all summer. I was home over easter break and started my 63 c10 up only to find that it would run, but wouldnt move when i switched it into gear (turbo 350 automatic trans). in the past it has had some hesitation getting moving at times after it hasnt been driven for a while. but this time for whatever reason the thing just wouldnt move at all whatsoever. just wondering if anyone has any ideas as to the root of this problem. thanks.
63custom #638033 04/15/2010 11:26 PM
is it a automatic or standard. if it's automatic does it have plenty of tranny fluid? if it's a standard is clutch engaging? if it's automatic it's prob the tranny. good luck!
automatic, sorry i didnt include that, and it has a 283 sbc if that makes a difference.
havent checked the tranny fluid but i will do that when i get home next month.
63custom #638076 04/16/2010 2:00 AM
Socket Breaker
Socket Breaker
check the trans. fluid and also the vacuum line going from the intake/carb. to the transmission.
-W
Woogeroo #638083 04/16/2010 2:16 AM
alright will do. i appreciate the help.
