2 members (carbking, TUTS 59),
108
Mod | | | Forums66 Topics128,029 Posts1,055,416 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 61 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 61 | O.K. so I need to remove my 1964 C20 Parking brake band. Is this a simply remove and reinstall, or should I know something. Any help would be helpful. I just received the 64 Supplement Manual and no notes on this subject. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It's pretty simple but it's hard to get back together unless you do it every day. Take pictures & notes so you know were each spring & part goes. The adjustments are pretty obvious. After you get it snuged up & centerred adjust the long 1/4 in bolt to keep it from drooping & dragging. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2010 Posts: 61 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 61 | Thanks Wrenchbender. You always give me the best answers. It's pretty simple but it's hard to get back together unless you do it every day. Take pictures & notes so you know were each spring & part goes. The adjustments are pretty obvious. After you get it snuged up & centerred adjust the long 1/4 in bolt to keep it from drooping & dragging. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i don't think the suppliment will help it didn't change from the 63 manual. best i remember my 64 was pretty easy, but it's been 5 years ago. | | | | | Joined: Mar 2010 Posts: 61 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 61 | No the 1964 Supplement had no info on this brake it has the other brake information. thank anyway i don't think the suppliment will help it didn't change from the 63 manual. best i remember my 64 was pretty easy, but it's been 5 years ago. | | | | | Joined: Mar 2010 Posts: 22 New Guy | | New Guy Joined: Mar 2010 Posts: 22 | Not sure if you got your brake back together yet...but I just finished reinstalling mine two days ago on my '64 C20. I have the '63 manual with the complete directions if you need them.
From memory: 1) The positioning (centering) bolt on the case should be turned until it allows .01-.015 clearance from the pad to drum. 2) Then the smaller bolt should be turned up so it allows .30 clearance from the bottom pad to bottom of drum...with a .10 shim diametrically positioned. 3) Finally the big "J" bolt turned until .30 clearance from top of pad to top of drum...with a .10 shim diametrically positioned.
Hope this helps!
1964 Chevy C20
| | | | | Joined: Mar 2010 Posts: 61 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 61 | Thanks I just received the 1963 Servicr Manuel and I have the info to start and finish the job. | | |
