| | | Forums66 Topics128,186 Posts1,057,324 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 35 Apprentice | | Apprentice Joined: Mar 2010 Posts: 35 | The truck is a '62, C10, 3 Speed, Long / Wide Bed that was sold new here in North texas as a "Fleet Truck". I have heard that there were several different sized in-line 6 cylinder engines. How do I tell what size mine is?? | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | 62 is the last year for the 235 and is most likely the engine you have being a C10. There is a flat spot on the block directly behind the distributor with numbers stamped on it. Post these numbers and someone will identify the engine.
Evan
| | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | How many valve cover bolts does it have? | | | | | Joined: Mar 2010 Posts: 35 Apprentice | | Apprentice Joined: Mar 2010 Posts: 35 | If I recall it has 6 flat head screws that bolt down the valve cover. I just tweaked them down and I believe there was 6 of them. I will double check tonight when I get in, post a picture, and see if I can't locate the numbers stamped behind the distributor. Thanks!! | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | I'll hijack a thread. Have a '48 6100, with i believe a 235. Only numbers that I could find were B53 848 850 above and to the front of the distributor and 3836848 cast onto the head. I've looked at the post on here and at inliners and can't figure out what motor it is. hoping someone can chime in and answer.
thanks | | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | The block casting number is sometimes under a ridge and forward of the fuel pump making it hard to see. That's where I found my 3701481. I've read where you can lay a piece of paper on it and rub it with a dirty, greasy finger and get the number transferred. "Hidden" block casting number. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | aggie jon - Your number: B53 848 850 is not an engine number, but the head number indicates it is a "848" head, the desirable head, from 58-62, used on many of the earlier engines to enhance performance.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | hmmm, interesting. Did not realize that this was not the original engine. not surprised. now i am really intrigued. | | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | The 194, 230, 250, and 292 have seven valve cover bolts.
Joe | | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | Aggie-Jon,
I hope I'm not spreading misinformation, but I've always thought that a casting like your "B53" gives you the date of casting. B53 = Feb. 5, 1953.
Of course, that only worked for a certain 10-year period. I don't know what they did in 1963.
The 235 in my '48 had a B33 casting (Feb 3, '53). LAQ83376 was stamped on the flat spot behind the distributor. The head was B23.
My current 261 has an A241 casting (Jan. 24, 1961?) in addition to a 3769925.
That longer casting number will give you the engine size.
| | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | After some further review and selection, I found the following numbers - 05(6 or 5)(8 OR 3)83(I or T)F547
Most likely 05683IF547. Was hard to read with bad light and dirty cast. Maybe I can get inside the ballpark. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The "B53 848 850 above and to the front of the distributor" has never been satisfactorily explained/decoded.
The 3836848 head casting code was used on 235 engines from 1956 through 1963. And, as posted by Big Tee, it was also the code on replacement heads for high-pressure 235s from 56 until they stopped making them. The date casting code on those heads would be a clue as to the head being original or a replacement.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Call Patricks's and get their catalog. It has a whole section on casting #'s and years built. Best of all it's free! | | |
