7 members (Otto Skorzeny, J Lucas, klhansen, Tronman, electors, 78buckshot, 1 invisible),
106
Mod | | | Forums66 Topics128,042 Posts1,055,497 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 210 Shop Shark | | Shop Shark Joined: May 2008 Posts: 210 | I have a couple spring clips that are broken on my leaf springs. In all cases it is just one side that is broken. Is this a big deal? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | well, I would say you have to take the spring out that has the broken spring clip.. unless you try to weld a piece to it but I havn't seen very many that are welded that I liked.
In order to do a good job you need to take that spring leaf out of the set so you can grind off the bad rivet and knock it out. With the spring leaf out you can make you another spring clip outt of a piece of 3/4" flat steel. Drill a hole in it and then attach it with a new rivet by pressing the rivet flat with a fair size press. I did mine and they came out nice..... once you get the piece riveted to the spring you put it in a vice to hit/bend it with a hammer. See Denny Grahams link in a post here in this forum. He is the one that gets tht credit for me getting mine done. | | |
