2 members (Hotrod Lincoln, latroca52), 73 guests, and 5 robots.
Topics128,024
Posts1,055,395
Members48,422
#637309 04/13/2010 3:12 PM
My speedo in my '55 Chevy truck is off by about 20 MPH. Where can I get a different gear to try and how do I know how many teeth I need? I had the original transmission in it and it was off. Now I have an overdrive in it and it's off the same amount. Could it be my speedo or is it likely the gear in the trans?
if it was off the same amount with the original trans, it's unlikely to be the wrong gear .... more likely that the speedo mechanism is gummed up after 55 years, and if the speedo has ever been messed with it could just be the needle is mis-positioned - notice whether it starts to move as soon as you let out the clutch or 'jumps up' once you're moving faster [or drops to 0 before you're stopped]
That's a darn good point about the needle. Does it just pop off so I can turn it. It is off about 20 mph across the board. It barely starts coming up when I'm in town.
You should be able to find your Speedo answer here.
Many pages of info after this one.
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0397.htm
Keep in mind, that an incorrect tire size
will change your speedo output.
-Tom
1950 Chevy 3100 w/ 1956 235
How does the odometer track with mileage markers on the highway?
The odometer is gear driven and is a direct reading from the transmission, the speedometer is magnetic driven and relies on magnetic pull to spin the needle. A odometer error is due to transmission gearing, both odometer and speedometer error (if off same amount)is the gears, and just a speedometer error is in the speedometer head.
Drive the truck ten miles on the interstate, watch the odometer closely, then figure the difference between the two after ten miles. Say you lost 1 mile out of ten, thats a 10 percent error. Now count the teeth on the driven gear in the trransmission and reduce the number by 10 percent.
Smaller gears turn faster which add miles, larger gears turn slower and count fewer miles.
If the odometer is close and speedometer is still off, your speedometer head need cleaned and/or repaired. Most will loose a percent the faster you go, but around 35 they should track right on. As the magnet gets old it weakens and just can pull the needle like it used to and if the needle assembly is dirty, it just adds to the problem.
Joe
That is a great post Joe, but aren't our older speedometer needles regulated by a spring instead of a magnet? That is all good information to tuck away in the recesses of my feeble mind as I have at least three speedometers to get working again.
Joe
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
'mater - the speedos do have a spring in them, but the magnet is what drives them .... and note magnets don't "weaken with age", that's why they're called permanent magnets, dirt buildup will be the problem
Too fast usually indicates a weak spring. Too slow is dirt. Too slow is much more common than too fast. In fact too fast is very uncommon. An erratic needle usually means the cable needs grease
OK, I stand corrected..... but mine looses speed the faster I go and the odometer is dead on. I just assumed the magnet was causing this, maybe its time for another cleaning!
Joe
My problem, speedo is slow to come up especially when it is cold.How do you clean them? 59 Apache 235
check the tech tips link, top of the page
taking it apart is not a good idea unless you have instrumentation experience.I would sent it to Scott's in detroit family business they will get you fixed up.Lou.
1951 chevy 3100 short bed frame off resto.
