Your right, those 8 rubber spacers are for the rear shackle mounts.
When I rebuilt mine I ended up reusing the old rubber, just cleaned up and lightly greased.
Use the search engine here before you mount your cab. There is a certain dimension you need to shoot for when you mount your cab. search....AD cab installation its in the paint and body shop forum
rear mount cab mount inside cab
