4 members (HandyAndy, Hotrod Lincoln, Otto Skorzeny, Guitplayer), 181 guests, and 1 robot.
Topics128,034
Posts1,055,541
Members48,425
#636588 04/11/2010 2:57 AM
I have a small block chevy, and am having some trouble with the year of manufacture. The casting # is 3849852, the casting date is E144, and the only number that I can find for an engine I.D. code (stamped,on boss on block in front of r.hand cylinder head), is F05I5D. The engine also has a generator and road draft tube. It would seem to be a 283 manufactured in May of 64, but the road draft and gen. confuse me. Did the truck continue with these after 1962? Any suggestions?
According to my book, that engine was built in the Flint plant on May 15th in 1958, 1959 or 1960. It's a 170hp 283, 2bbl small block.
Best I can do,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Thanks for the info. Larry
H Online: Content
If it's got the original cylinder heads on it, the valve cover bolt hole spacing will be wider on the bottom than the top. I believe they changed to even-spaced valve cover bolt holes in 59. Those original heads with the offset holes are fairly scarce and expensive, BTW, if a restorer needs them.
valve cover bolt holes measure 8-3/4" center to center, top and bottom.
H Online: Content
It sounds like you've got newer heads than the block, or the engine was made post-1959. There are several websites where you can research head and block casting numbers, but there's a very strong possibility newer heads have been installed sometime during the past 50 years. The shape of a machined pad on both ends of the heads can give you an idea of which ones you've got. There were several different valve sizes and compression ratios on 283's over their production run, as that engine was used for everything from big trucks to Corvettes, and there were several engine options with different horsepower ratings on regular passenger cars.
Listed as:
283 Engine
Block Casting # 3849852
Block Casting date: May 14, 1964
Engine assembly: Flint, May 15. "D" code ??
Truck 1958 - 1967
Passenger 1958 - 1962
-Tom
1950 Chevy 3100 w/ 1956 235
Oilrag #637092 04/12/2010 10:08 PM
I agree with the block casting date of 1964, however I am confused about why the engine would still have a road draft tube and a generator after 1963.
larrybell #637112 04/12/2010 11:00 PM
ive got a 66 c30 extended wheelbase w 10k gvw, its got a road draft tube, but the alternator on it may have been put on later i suppose.....
everybody is ignorant @ something.the more we work together, the less ignorance there is floating around
F= Flint
05=May
15= 15th of May
D= 283 of either 1958,59 or 60
Mortec Tech says it was cast from 58-66
I don't see any listings for a "D" code 283 in 1964 which would explain the road draft tube!
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
What is the generator Model #.
-Tom
