| | | Forums66 Topics128,167 Posts1,057,015 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 27 New Guy | | New Guy Joined: Sep 2009 Posts: 27 | hi my 59 trucke with a 235 engine has a rocheter monojet carb on is this the right one thanks gregor | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That's not the one it came with. It originally had a model B or possibly a Carter YF but not likely. The Monojet is an improvement if it is installed & calibrated correctly. It did not come out until 68.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2010 Posts: 17 New Guy | | New Guy Joined: Apr 2010 Posts: 17 | Hi Wrenchbender - my'58 Apache 235 half ton stepside runs too rich. The plugs are black and consumption too high. It's had two Rochesters fitted to an Offenhauser manifold,but they can't be turned down any more or it won't run. Do you know of other carbs I could use that would be more suitable, and where I could get them? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I havn't worked with multiple carbs. since way back in the flathead Ford days. First make sure the power valves are working & the float level is correct. There is a hole in the bottom of the carbs that must have a passage in the gasket to the intake manifold. Those are the basics. You may have to put leaner main jets in or weaker springs under the power valve rod. You might try lowering the float levels a little. You can use Carter carbs but they will have to be taylored also & are much harder to work with. A lot of guys use the Weber carbs. on those & report good results but I havn't used them on this kind of engine. We used to have a lot of them on the old Pinto's & Mustang's & they were tempermental. If some of the fellow Stovebolters have more to ad please jump on in. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
