3 members (BC59, Bill Hanlon, klhansen), 129 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
hi my 59 trucke with a 235 engine has a rocheter monojet carb on is this the right one
thanks
gregor
yes, that's the one
Riding in the Passing Lane
That's not the one it came with. It originally had a model B or possibly a Carter YF but not likely. The Monojet is an improvement if it is installed & calibrated correctly. It did not come out until 68.
1972 Chevy c10 Cheyenne Super
Hi Wrenchbender - my'58 Apache 235 half ton stepside runs too rich. The plugs are black and consumption too high. It's had two Rochesters fitted to an Offenhauser manifold,but they can't be turned down any more or it won't run. Do you know of other carbs I could use that would be more suitable, and where I could get them?
I havn't worked with multiple carbs. since way back in the flathead Ford days. First make sure the power valves are working & the float level is correct. There is a hole in the bottom of the carbs that must have a passage in the gasket to the intake manifold. Those are the basics. You may have to put leaner main jets in or weaker springs under the power valve rod. You might try lowering the float levels a little. You can use Carter carbs but they will have to be taylored also & are much harder to work with. A lot of guys use the Weber carbs. on those & report good results but I havn't used them on this kind of engine. We used to have a lot of them on the old Pinto's & Mustang's & they were tempermental.
If some of the fellow Stovebolters have more to ad please jump on in.
