7 members (eclector, 32Fordpuchoptop, Hotrod Lincoln, dt235sd, MickeyP, 2 invisible), 154 guests, and 1 robot.
Topics128,033
Posts1,055,531
Members48,425
#636670 04/11/2010 12:58 PM
Can anyone offer an alternative method to stapling the beaded window seals to the inner window frame on a '53 3100?
Glue/Adhesive
Pop Rivet
I used the Black Weatherstip Adhesive. No regrets yet but its only been sitting in the shop since doing it.... I might add that I wish I had found the little strips that are pre-curved on the inside door trim piece. Most of the vendors only sell it straight. But there is one vendor that has the kit with the curved pieces in it. I think the kit was $29.
Alvin- Thanks to your earlier tip about the curved strips I got the entire window weatherstrip package from American Classic Trucks,who offer the curved cat whiskers. I am impressed with the quality of all the parts. More expensive than many of the other vendors but good quality. I haven't seen anyone else's products to compare however but I am satisfied.
Chuck
Yep, you can glue, screw, rivet all those things or you can do it the way they were done at the factory originally, i.e. staple. The staples that the vendors sell probably won’t be the correct spacing, at least the ones that I bought weren’t. So I made my own staples with the correct spacing; http://www.pbase.com/dennygraham/image/123537640/large
Transferring the staple holes one at a time isn’t all that much of a challenge. The hardest part is holding the staple tight while you bend the backside over.
http://www.pbase.com/dennygraham/doors&page=2
http://www.pbase.com/dennygraham/doors&page=3
Also, unless you want to make up a bender like the one pictured then I would definitely buy the pre-bent cats whiskers they are well worth the little bit extra. Twenty-nine bucks also includes the outer rubber wipers. If you’ve tried bending the cats whisker then you know what we’re talking about.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Moderated by  ndkid275, Phak1
