6 members (Stovebolt48, cmayna, Gone, Rusty Rod, Gdads51, 1 invisible), 83 guests, and 3 robots.
Topics128,187
Posts1,057,312
Members48,468
my vacuum 2 speed controller isnt hooked up and im not sure if im in low range or not.i get up to about 35mph in 4th gear with a 261.hopefully im in low range?is there a way to manually switch it?Thanks
Dan
3B Offline
Hy dantheman49-6400, the vacuum two speed requires vacuum to shift it into high range, the controller under the dash says to park in low, hope that helps.
Vacuum pulls it into high, a spring keeps it in low. Unless the spring is broken, it would be stuck in low.
alright, so as long as i have no vacuum hooked up, it will stay in low? is that what im hearing?
Dan
If the spring that holds it in low isn't broken, that is correct.
