2 members (pauld, Goach2),
68
Mod | | | Forums66 Topics128,185 Posts1,057,286 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | my vacuum 2 speed controller isnt hooked up and im not sure if im in low range or not.i get up to about 35mph in 4th gear with a 261.hopefully im in low range?is there a way to manually switch it?Thanks Dan
| | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy dantheman49-6400, the vacuum two speed requires vacuum to shift it into high range, the controller under the dash says to park in low, hope that helps. | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | Vacuum pulls it into high, a spring keeps it in low. Unless the spring is broken, it would be stuck in low. | | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | alright, so as long as i have no vacuum hooked up, it will stay in low? is that what im hearing? Dan | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | If the spring that holds it in low isn't broken, that is correct. | | |
