| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 197 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 197 | When I ran a wire direct from the sending unit to the gauge, it went off of the perpetual "past full", to 3/4 which should be an accurate reading. Problem should be in the wire between sender/gauge or connection issues...right? Somewhere in the testing procedure, I had decided to disconnect sender wire, and while unscrewing, I failed to notice that the bottom nut, along with electrical post was spinning at the same time. I think I have managed to screw up my sending unit, because I can not replicate the above test. Lacking X-ray vision, and never had a sending unit apart, would this be something I could repair, or do I need a new sender?
| | | | | Joined: Sep 2005 Posts: 50 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 50 | The post just goes through the plate to a metal strap, as long as the two are connected it will work, however if you grounded your (that post/strap) + side, you could have blown the gauge. Gauge Test w/o sender, actually when you ground the gauge + side, it should read full, the only way to know if the sender is working is to either put gas in the tank, or pull the sender, reconnect + & ground, and lift the float as if you were filling the tank, then you will know if the sender is working, as long as you know the gauge is good. | | | | | Joined: Aug 2009 Posts: 197 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 197 | Thanks, I am sure that gauge is still good, but needed info which you provided about sending unit...thanks | | |
