6 members (TexasA&M48Truck, Charles in CA, MickeyP, Nick in Manitou, Ponchogl, 55shaker), 125 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#63493 07/26/2006 11:01 PM
does the 1974 chevrolet nova have a full frame or is it a unibody type frame? thanks Bill
#63494 07/27/2006 3:52 AM
I think it has a front subframe attached to the uni-body,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#63495 07/27/2006 5:42 AM
Jed Offline
55,
I can't tell you with any confidence about the earlier versions, but all of the Novas from 68 - 79 were uni-body cars with subframes.
Just in case you're thinking about using the subframe in another vehicle, double check the width. There's a pretty good difference in the width between the subframes used in the late 60 - early 70's and those used in the mid to late 70's.
#63496 07/28/2006 6:57 PM
thank you Jed sorry about the 1874 hit the wrong key it is a 1974 Nova. Bill
#63497 07/29/2006 5:25 PM
The 1974 nova is a uni-body /subframed car. It is also a rear steer car. In 1975 Chev went to a front steer and is about 4" wider than the 68-74 Nova. Somebody will correct me if wrong. Here is a link for front and rear end widths:
http://50chevy.freeservers.com/Suspension_Widths.html#Suspension
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
