1 members (1 invisible),
46
Mod | | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63493 07/26/2006 11:01 PM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | does the 1974 chevrolet nova have a full frame or is it a unibody type frame? thanks Bill | | |
#63494 07/27/2006 3:52 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I think it has a front subframe attached to the uni-body, Scott | | |
#63495 07/27/2006 5:42 AM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | 55,
I can't tell you with any confidence about the earlier versions, but all of the Novas from 68 - 79 were uni-body cars with subframes.
Just in case you're thinking about using the subframe in another vehicle, double check the width. There's a pretty good difference in the width between the subframes used in the late 60 - early 70's and those used in the mid to late 70's. | | |
#63496 07/28/2006 6:57 PM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | thank you Jed sorry about the 1874 hit the wrong key it is a 1974 Nova. Bill | | |
#63497 07/29/2006 5:25 PM | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | The 1974 nova is a uni-body /subframed car. It is also a rear steer car. In 1975 Chev went to a front steer and is about 4" wider than the 68-74 Nova. Somebody will correct me if wrong. Here is a link for front and rear end widths: http://50chevy.freeservers.com/Suspension_Widths.html#Suspension
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
