3 members (5 Window 9434, klhansen, Otto Skorzeny), 121 guests, and 12 robots.
Topics128,077
Posts1,056,017
Members48,433
#634537 04/03/2010 7:53 AM
Hi,Will a 1972 Chevy 250 6cyl bolt up to a 3 speed from a 1953 Chevy 235 6cyl and are all the mounts the same ? Are there any tricks to be aware of ? Thanks, Bruce
The later generation engines use side configured engine mounts and not the front mounts used by your 53'. However conversion mounts are readily available. I do believe that the tranny can be used if your bellhousing will work on the later engine, I'm not sure but others else can tell you that. It would make a nice swap as those are good engines.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
On trucks the trans bolt pattern from 1948 up is the same. It is also the same pattern as 1955 and up on cars.
My Blog
Riding in the Passing Lane
You have to use a bell housing from a 55-72 v-8 or 63-72 6 cyl. You need a crossmember from a 54 that goes under the bell housing or modify your crossmember. There are some variations in the bell housings. The 68 up with the sm465 4 speed has a larger center hole. The early 60's had the clutch arm on the right side.
1972 Chevy c10 Cheyenne Super
