| | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 40 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 40 | Hi,Will a 1972 Chevy 250 6cyl bolt up to a 3 speed from a 1953 Chevy 235 6cyl and are all the mounts the same ? Are there any tricks to be aware of ? Thanks, Bruce | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | The later generation engines use side configured engine mounts and not the front mounts used by your 53'. However conversion mounts are readily available. I do believe that the tranny can be used if your bellhousing will work on the later engine, I'm not sure but others else can tell you that. It would make a nice swap as those are good engines. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | On trucks the trans bolt pattern from 1948 up is the same. It is also the same pattern as 1955 and up on cars.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You have to use a bell housing from a 55-72 v-8 or 63-72 6 cyl. You need a crossmember from a 54 that goes under the bell housing or modify your crossmember. There are some variations in the bell housings. The 68 up with the sm465 4 speed has a larger center hole. The early 60's had the clutch arm on the right side. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
