5 members (dbwr, MickeyP, Gdads51, Steelonsteel, 1 invisible), 22 guests, and 8 robots.
Topics128,013
Posts1,055,312
Members48,419
#634504 04/03/2010 3:49 AM
I am hoping that a few of you will share some info. and suggest what would be best to put on the interior of your cab floor(53 3100s) under the seat and tank after it has been media blasted,To insure there will no moisture or least possible rust in the future. Is epoxy primer the only way to go?
fifty3 #634513 04/03/2010 4:40 AM
Since you have sandblasted it and for the specific place your putting it I think POR15 would work nice....just my opinion.
Achipmunk #634536 04/03/2010 7:46 AM
Mine too!
You shouldn't need to overcoat either, as that area will probably never see the sun once the trucks done.
More pix on Flickr.
I blasted and painted the seams where the rust tends to be with POR-15 and top coated that with epoxy primer. There are directions for dusting the POR-15 with primer on ther site. Then you let it cure and prime. Just my best shot at it.
