0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63405 07/24/2006 2:19 AM | Joined: Jul 2006 Posts: 12 New Guy | | New Guy Joined: Jul 2006 Posts: 12 | I am currently cleaning up the small block Chevrolet engine in my '66 K10 4x4 shortbed, and I was wondering what a good carburetor is for 4 wheeling. I've got a Rochester 2 Jet 2gc 2 barrel carburetor on it right now, it was on the truck when i bought it, and research shows the carburetor came on a 1975 Chevrolet car with an automatic transmission. Does anyone know what kind of CFM these carburetors flow, and how well they take to bumps and steep inclines? :confused:
-Rodney Hershkowitz
Chevrolet, An American Revolution. Somethins Wrong Cletus!!!
#63406 07/24/2006 2:27 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I had a '70 Blazer that ran a Holley 4 barrel just fine. My current 4x4 has TBI but almost never goes offroad.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#63407 07/24/2006 5:24 PM | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Carters make some of the very best carburetor for off-road, as Carter did much R & D on the subject.
Changing the intake would be necessary, but a Carter AFB would make an excellent choice.
For a 283:
Carter 9400s or 9410s
For a 327:
Carter 9500s or 9510s (both electric choke) Carter 4758s (manual choke)
For a 350:
Carter 9625s or 9635s (NOT 9635sa) (both electric choke) Carter 4759s (manual choke)
Modify the unit you choose by installing the special Carter marine/off-road spring-loaded fuel valves.
All of these carbs were produced PRIOR to 1985. I won't personally use or recommend the newer units.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#63408 07/25/2006 4:17 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If you're worried about fuel starvation, you also need to worry about oil starvation too, Scott | | |
