1 members (Bill Hanlon), 156 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#63405 07/24/2006 2:19 AM
I am currently cleaning up the small block Chevrolet engine in my '66 K10 4x4 shortbed, and I was wondering what a good carburetor is for 4 wheeling. I've got a Rochester 2 Jet 2gc 2 barrel carburetor on it right now, it was on the truck when i bought it, and research shows the carburetor came on a 1975 Chevrolet car with an automatic transmission. Does anyone know what kind of CFM these carburetors flow, and how well they take to bumps and steep inclines? :confused:
-Rodney Hershkowitz
Chevrolet, An American Revolution.
Somethins Wrong Cletus!!!
#63406 07/24/2006 2:27 AM
I had a '70 Blazer that ran a Holley 4 barrel just fine. My current 4x4 has TBI but almost never goes offroad.
#63407 07/24/2006 5:24 PM
Carburetion specialist
Carters make some of the very best carburetor for off-road, as Carter did much R & D on the subject.
Changing the intake would be necessary, but a Carter AFB would make an excellent choice.
For a 283:
Carter 9400s or 9410s
For a 327:
Carter 9500s or 9510s (both electric choke)
Carter 4758s (manual choke)
For a 350:
Carter 9625s or 9635s (NOT 9635sa) (both electric choke)
Carter 4759s (manual choke)
Modify the unit you choose by installing the special Carter marine/off-road spring-loaded fuel valves.
All of these carbs were produced PRIOR to 1985. I won't personally use or recommend the newer units.
Jon.
The Carburetor Shop
#63408 07/25/2006 4:17 AM
If you're worried about fuel starvation, you also need to worry about oil starvation too,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
