2 members (carbking, RLB), 157 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#633929 04/01/2010 2:13 AM
TJ
Offline
Howdy folks,
I hope that I'm not being redundant with this question, as I'm sure its been asked at one time or another.
I'm looking for a four barrel manifold for a chev 216 or small port 235 that can be used with the stock exhaust manifold.
In searching the net I see lots of double, triple and even three deuce manifolds for these engines but no four barrel.
Any help in pointing a wayward soul in the right direction appreciated: Thanks!
TJ #633935 04/01/2010 2:19 AM
The 'OLD' Clifford 235 4 barrel intakes would bolt up to stock 235 exhaust, not sure about their current stuff. You may call Patricks in AZ. Ph 520 836-1117 or www.patricksantiquecars.com
1946 1/2-Ton Chevy
TJ #634008 04/01/2010 9:58 AM
clifford performance
This is Clifford's site. I've been looking around for a nice 4barrel manifold myself so I can do a TBI conversion. As JiMerit stated, the old Clifford's will work but the new manifolds are coolant heated and require modification to fit a stock exhaust manifold.
