2 members (jay d, Gdads51), 75 guests, and 2 robots.
Topics128,265
Posts1,058,360
Members48,485
#633572 03/30/2010 10:34 PM
Having cab blasted today. What is the best primer to use as a temporary fix. I am going to do body work further down the road, but needing to cover. The floorboards are solid just pitted. I'm going to use por-15 them, but what about the cab metal. A cheap lacquer primer until the bodywork is done? Any help is appreciated.
The best things in life are FREE!
I am the antithesis of a painting expert but I used epoxy primer. It seems to be most commonly recommended for what you are doing. It will seal and weatherproof your metal until you are ready for the next step.
Chuck
I'll second the epoxy route.
I've used a high build 'rattle can' primer and have had bleed through in a couple of places that got wet. (leaky garage!)
AFAIK Most primers are porous.
More pix on Flickr.
Epoxy Primer. You can use filler over it (after roughing it) and If you have to hammer out a dent, you can always spray more. It is by far the best way to go. If it will sit around for awhile before top coating, you will need to sand it for good adhesion.
If you plan on using POR-15, apply it directly to the metal, not on top of the epoxy. I did this (a recommendation from a local paint shop) and where I did not sand the epoxy enough, the POR-15 did not adhere very well. I won't be taking advice from that paint shop again!
use self eching on the bare metal then scuff for body work do ur por 15 and while still tacky spray with self eching over the por 15 then it will take regural paint when ready. my brother does this for a living.this is his advise
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
Hillbilly has the best solution and it is what I did. Good luck with your project smile
Hank
1951 restoration on website
http://www.hanklong.com
well how did i turn out and what did u do
AND A MARINE
I use an etching primer when I know it will set and have to do work later. Cheaper and seals the metal. Then when all body work it done, a good sanding and sealing primer, followed by a base coat and top coat. Since most sealing primers have a time limit to when you need to apply the base coat. The etching primers don't need to be applied that heavy and leaves you with less sanding to keep the crisp lines. IMO
1937 Chevy 1/2-Ton
