Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Hotrod Lincoln, ShopRag, 59 fleet, Otto Skorzeny, Gdads51), 58 guests, and 1 robot.
Topics128,009
Posts1,055,291
Members48,419
#633697 03/31/2010 12:58 PM
I own a 1964 C20 and was considering inastalling a push buttom start.
Anybody have info and HOW TO and this subject. I want to use my key to power up and then push a button to start the engine.
Thanks.
You can cut the purple wire, after it leaves the neutral safety switch (with auto trans) on it's way to the starter and install a button switch on the dash. If it is a stick shift, you should see a jumper in the harness under the dash,left side. Open it up there and install your switch.Hope this helps!
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
gtow69 #633848 03/31/2010 9:50 PM
Riding in the Passing Lane
You will need to hook the purple wire going to the starter to one side of the button & a hot wire, about 12 gauge, to the other connection on the starter button.
1972 Chevy c10 Cheyenne Super
