BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
7 members (Gib70, greenie-reddy, bucktruck, 1942-G506, Lightholder's Dad, 2-Ton, Otto Skorzeny),
583
robot. | Key: Admin,
Mod | | Forums66 Topics126,776 Posts1,039,258 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Mar 2010 Posts: 61 Shop Shark | Shop Shark Joined: Mar 2010 Posts: 61 | I own a 1964 C20 and was considering inastalling a push buttom start. Anybody have info and HOW TO and this subject. I want to use my key to power up and then push a button to start the engine. Thanks. | | | | Joined: Jan 2006 Posts: 586 Shop Shark | Shop Shark Joined: Jan 2006 Posts: 586 | You can cut the purple wire, after it leaves the neutral safety switch (with auto trans) on it's way to the starter and install a button switch on the dash. If it is a stick shift, you should see a jumper in the harness under the dash,left side. Open it up there and install your switch.Hope this helps!
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You will need to hook the purple wire going to the starter to one side of the button & a hot wire, about 12 gauge, to the other connection on the starter button. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
