0 members (), 129 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
I was wondering if someone could take and measure the distance from the center bottom of the window to where the bed front comes to.... The reason why I am asking is that I went ahead and cut 21in out of my frame rails on my 1 ton and need to figure out the height of the blocks I need to make for the frame to sit level like on a 1/2 ton. Hope that makes sense.
Thank you
If I understand the question right you are looking for a height dimension. If not that, the answer is about 2" between the cab and the front bed panel. We discussed this at length a few months ago.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Height is correct from the bottom of the window frame to the top of the bed front panel. The distance between the cab and the bed.... Not really needed, but I am not worried about that since everything will be custom fabricated anyway.
Did anyone get a chance to check this measurement for me? I would really appreciate it. I have the welder coming this week to sure up the frame, the next step is putting the bed on it.
go ahead and weld it ...........
care to chat write back
The welding is not an issue, how high to mount the bed above the frame rails are. I need to make the spacers for that, but considering it is a 1 ton the only reference point I will have is from the bottom of the window down to where the Bed starts.
The window as installed? or the window opening? A better place to measure from might be the body band. I have 10" between the bottom of the body band and the top of the front bed panel. Fair warning though my truck is not stock.
1953 Chevrolet 3600
The body band works. I just figured that the window was another reference point to work off of. I will have to see where 10" Puts me. I was playing with a side last night on the truck with a fender bolted on and it seems like it is really off where I had it, I assume I need to lift it 3 in based on where the running board is on my truck vs where the guy decided to weld the other one to the fender.
Thank you.
