5 members (ShopRag, Phak1, Bill Hanlon, Otto Skorzeny, 3B), 116 guests, and 4 robots.
Topics128,034
Posts1,055,547
Members48,425
#633276 03/30/2010 12:14 AM
I have a '53 3100 and was going to drain the diff.......I see the fill plug, but is there a drain plug are I am just blind. Do you remove the cover to drain the fluid? Help!
On my '53 3600 I just remove the bottom cover bolt to drain it. That should allow most of the fluid to drain out.
You can loosen a couple of the bottom bolts and the fluid will drain out. I would prefer to take the cover off and have a peek inside. Then a new gasket or something similar and refill from the plug you see.
While you are there check your differential breather to make sure its not stuck. Its the little bump on top of the axle on the driver's side. It should move freely.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
At least now I know I'm not nuts! I think I will take a peek inside. Thanks for the heads up on the breather.
On my '49 you can drain the differential by removing one of the lower most bolts. the hole goes thru the casing. It is a good idea though to peek inside as noted above.
Ed
