| | | Forums66 Topics128,268 Posts1,058,382 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | Just got back from a little cruise.Truck started running rough and idle is higher,missing too I think,what could this be?Thanks
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Vacuum leak, blew the carb out need to tune carb again, distributor slipped timing is off. Any more sdetails?
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | I'll start checking those things,thanks. | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | If you're still running points and have a dwell meter you might want to do a check, or just check the point gap with a feeler gauge. Common problem with points, or if not used very often - either the points get pitted/burned or the rubbing block wears down, which changes both the dwell and the timing.
This doesn't usually cause the idle increase however, that is more likely a vacuum problem. | | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | yes, running points still.I am leaning towards a carb. issue.Thanks and I'll post the results. | | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | Carb. needs to be rebuilt,that's the mechanic's conclusion. | | |
