2 members (Jay R, Donf),
71
Mod | | | Forums66 Topics128,026 Posts1,055,405 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | I have a '53 3100 and was going to drain the diff.......I see the fill plug, but is there a drain plug are I am just blind. Do you remove the cover to drain the fluid? Help! | | | | | Joined: Jan 2009 Posts: 256 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 256 | On my '53 3600 I just remove the bottom cover bolt to drain it. That should allow most of the fluid to drain out. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | You can loosen a couple of the bottom bolts and the fluid will drain out. I would prefer to take the cover off and have a peek inside. Then a new gasket or something similar and refill from the plug you see. While you are there check your differential breather to make sure its not stuck. Its the little bump on top of the axle on the driver's side. It should move freely. | | | | | Joined: Jan 2005 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 97 | At least now I know I'm not nuts! I think I will take a peek inside. Thanks for the heads up on the breather.
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | On my '49 you can drain the differential by removing one of the lower most bolts. the hole goes thru the casing. It is a good idea though to peek inside as noted above.
Ed
