0 members (),
200
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 61 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 61 | O.K. so I just purchased a 64 C20, 292 engine. I turn on my lights (low) then my high. I look at my dash and notice that the GEN lights lights up. Turn off high beams and GEN light goes off. Anyone have an answer. | | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | Somebody got the high beam indicator light and the GEN light switched around behind the dash? When you turn on the key without the engine running does the high beam indicator light up? | | | | | Joined: Mar 2010 Posts: 61 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 61 | I beleive it does go on. I am yet to familize myself with the truck (being my first)but I did notice upon turning the ignition ket that the word bright was lit up. I assumed that my high beams were on so I hit the switch but nothing happens, so I started the engine and processed with my lighing checks. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | so what you need to do Lucky, is reach behind and pull the 2 bulbs as you would do if one were burned out, and switch their positions - the're in simple snap-in sockets .... should change the behavior to what's correct, indicating you are lucky, hope all your truck problems are so easy on ya!  Bill | | | | | Joined: Mar 2010 Posts: 61 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 61 | Thank you. Yeah I do hope my truck would be this easy! | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I think your alternator belt is slipping. With the motor off, grab the pulley with a gloved hand and try to turn the pulley. If you can turn it even a bit , It's too loose and will need to be adjusted or the belt replaced.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
