1 members (Jimmie D),
110
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63203 07/19/2006 9:29 PM | Joined: Jan 2004 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2004 Posts: 70 | I need help from you engine experts! I had a rebuilt 350 put in my 51 3100 about 6 months ago, and although it only gets about 10mpg, it has run very strong and smoke free except for a few ocasions. The first time I noticed it, I was on a 60 mile drive. About 30 miles into it, the truck started smoking heavily for a few seconds every few miles. It seemed to happen more when the engine had a little strain on it, like going up a small hill. The smoke was blue/grey and smelled like oil smoke. 3 hours later, I drove it home with no smoking whatsoever. Since then, it has done it again a few times. It seems to happen only after I have a hard acceleration at highway speeds, then it may start to smoke a few minutes later. I usually drive it gently, and it never seems to smoke then. I changed the oil 500 miles ago, and it is still almost full. What the heck is going on? I'm going back to talk to the mechanic again, but he doesn't seem to have any good ideas about what can cause this to happen. Thanks for any help! | | |
#63204 07/19/2006 9:51 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Shoe, Any PCV valve or smog hardware on this rig? I don't see it mentioned, so it probably isn't turbocharged! Were the heads rebuilt when the engine was done? Does it have conventional brakes, or did someone stick power brakes on it? Stuart | | |
#63205 07/19/2006 10:22 PM | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Is the smoke coming out of the exhaust or out of the engine compartment? | | |
#63206 07/19/2006 10:34 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,m thinking PCV valve also. Some of the aftermarket valve covers don,t have shields around the vent holes. Pull the pcv valve out & see if there is oil in the hose. You have to have 2 sorses of vents. The pcv plus a vent cap or tube going to the air filter. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#63207 07/20/2006 2:50 AM | Joined: Jan 2004 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2004 Posts: 70 | Thanks, everyone. It does have a pcv valve, no other smog hardware. It does have front disc brakes with a booster, and power steering. I assumed the smoke was coming out of the exhaust pipe, but I'm not sute. It has dual exhausts, and it seems to come from the right side (passenger side) but all I've ever seen is through the rearview mirror. It does put out a lot of smoke for a second or 2, I think too much to be from the engine compartment. | | |
#63208 07/20/2006 3:30 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Shoe,
If the smoke is coming out of only ONE pipe, and they don't have a common connection under the car, you might be dealing with a head issue. Take a look at the tailpipe end and see if one appears more black or oily than the other.
Just for grins, and because they are cheap, ( I guess) replacing the PCV valve might not hurt.
Stuart | | |
#63209 07/20/2006 4:22 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Do you have a chrome valve cover that doesn't have a baffle under the PCV port? Scott | | |
#63210 07/20/2006 6:05 AM | Joined: Feb 2005 Posts: 68 Member | | Member Joined: Feb 2005 Posts: 68 | If it has an automatic trans you might check and see if the vacum modulator valve is leaking some transmission oil into the vacume hose going to the intake Ronnie | | |
#63211 07/21/2006 2:55 AM | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | i had a similar smoke issue. it turned out to be the intake manifold gasket on one side was allowing oil to get into the exhaust warming port of the intake manifold. tiny amounts of oil from the lifter chamber were going straight into the exhaust header on one side. it doesn't take alot of oil to make alot of smoke. the telltale sign for mine was drops of oil coming out of the collecter joint on one header when the engine was cooling down and parked on a hill. hope this helps. good luck.
our garage is a non-profit organization
#63212 07/21/2006 5:35 PM | Joined: Jul 2003 Posts: 132 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 132 | Let us know if it an automatic. It sure sounds like a vacuum modulator leak at low vacuum conditions. Have you noted any loss of trans fluid? | | |
#63213 07/21/2006 6:11 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Any oil pulled in through the intake would show itself out both exhaust pipes. Shoe has stated this "might" be coming out of one exhaust pipe only.
If this is true, it would lead one to believe that the problem was isolated to that bank.
Stuart | | |
#63214 07/21/2006 8:04 PM | Joined: Jan 2004 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2004 Posts: 70 | Thanks again. It does have an automatic trans (350) I checked the fluid level, and it still shows full on the transmission. Where do I find the vacuum modulator?
48bigtrucks- the valve covers are the stock covers. garyg- I'll look into the gasket leak, we did have problems with the exhaust manifold gaskets, maybe there are more bad gaskets in there! | | |
#63215 07/21/2006 10:05 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The modulator is a round chamber on the rear of the trans. It has a small vacuum hose attached to it. Remove the vacuum hose & if there is any fluid in it it is defective. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#63216 07/21/2006 10:41 PM | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | I wonder if the rebuilder accidentally got the ring gaps lined up with each other instead of staggering them. That would cause some blow-by in one cylinder and make the smoke only come out of one exhaust pipe.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
#63217 07/21/2006 11:32 PM | Joined: Jan 2004 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2004 Posts: 70 | I checked the modulator, there is no fluid in the vacuum hose. Phil- I don't think it is misaligned rings, it only smokes for a few seconds at a time, and has only done it a few times. | | |
#63218 07/22/2006 12:58 AM | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | Shoe, Pull the valve cover off and check to see if an oil drain back hole is clogged up. If the person that assembled the engine used excessive amounts of RTV "blue glue" when assembling the engine, some of it could have broke off and made its way to the cylinder head where it clogged the hole up. Hope this helps. | | |
