| | | Forums66 Topics128,167 Posts1,057,020 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | I appreciate any and all advice I get from you guys for sure.
I posted regarding fromt end wobble and all things point to the only thing left which is the steering box. Who in here has attempted this project and how did it turn out? Pretty sure that I can do it but need to hear from a few of you as to the possible issues I may or may not face.
Thanks in advance, Steve in Idaho | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | What I have found in the few that I have dissassembled (both cars and trucks) is that the bearing surface on the worm shaft is damaged. Generally the upper bearing runs out of grease and wipes out the bearing and the shaft becomes badly pitted. This surface is hard chrome and could be redone or the shaft replaced. There are kits available with bearings and small parts and the book gives a good rebuild procedure. There are a couple of sources in my area that do a good job rebuilding steering boxes and are reasonable. Fred
| | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Do you have instructions on how to remove the column? Looks like I have to drob the exhaust and jack it up pretty high to get it out. I did find the place in San Jose, CA which will rebuild it for $275. Do you have another source for rebuild?
Thanks Fred,
Steve | | | | | Joined: Feb 2000 Posts: 5,229 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,229 | | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | You will need a pitman arm puller. Set it up on stands, remove the wheel, pitman arm, steering wheel, turn signal, dash clamp, shift linkage, and mounting bolts and the whole column/gear box comes right out. If you have a V-8 truck, you will have to remove the left manifold. It should clear on a 6 cyl. I have used ABS in Orange CA. www.abspowerbrake.com.Fred
