3 members (ShopRag, Bill Hanlon, fonz8261), 141 guests, and 3 robots.
Topics128,125
Posts1,056,337
Members48,440
#631279 03/22/2010 11:13 PM
I know it's been discussed to death, But I haven't had much luck with the search....
'58 235 Rear main crank seal is leaking oil.
Question is do I need to drop the oil pan, or will I get enough slack in loosening the rear crank cap to sneak the new seal through?
Please tell me I don't need to take this oil pan off again....
1958 Chevy Apache Fleetside/235/3 sp
Pictures at http://www.facebook.com/album.php?aid=317454&id=855355703&l=0a0f773195
3B Offline
Hy Skidmarks, unfortunately I don't have good news for you, the only way to change the rear main seal that I know of is to remove at least the rear main bearing cap, if you're installing a rope type seal you may have to loosen the remaining main bearing caps. There is a synthetic seal available for that engine as well, Fel-Pro p/n BS13363, good luck.
3B #631323 03/23/2010 2:00 AM
Skidmarks,
Yep, the oil pan has to go. As 3B suggested you may need to loosen the remaining caps. The 58 rear mains were not machined for a neoprene seal, but if 3B has one, I wish I had known about it a bit earlier.
I just finished the same task, and put a rope seal back in. Loosened all caps to get enough clearance to pull the seal through, and you can do this without removing the oil pump screen.
Good luck,
Richard
58 3104
Another question on this - did you guys have to remove the tranny too?
3B Offline
Hy waldo53, It would definately allow the crankshaft more range of movement if the tranny was pulled back for enough to clear the clutch, but the job should be able to be done without that.
3B #631504 03/23/2010 7:32 PM
The 58 mains were not manufactured for the Neoprene, but can you put them in place of the rope? Everything I read says convert to neoprene if you can....
Skidmarks,
I have heard tales of people getting the rope seal back in with the tranny in, but I am not sure how. I could not get enough movement on the crank to allow clearance to get the seal in.
Removed the transmission, and while you are at it, how's the clutch? Perfect time to tackle that job.
Have fun,
Richard
58 3104
Actually, I have the engine in a bare chassis, I have the tranny out, and a new clutch kit in the box, ready to go in. I just need to get this seal replaced....
I don't want to put in a neoprene seal if it's not gonna last... Anyone?? rope or neoprene on a 58?
Skidmarks,
According to the Shop Manual, the 58 block was not machined to accept a neoprene seal; that started in the 1959 blocks. I put a rope seal back in, and have been happy with the results.
Neoprene is usually preferable, but if your block is not machined for it, it would likely leak like a sieve. Check the manufacture date on the block.
3B, do you have any additional info on that Fel-Pro item?
Richard
58 3104
