0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | I have a 12 bolt out of I believe a 1972 chevy truck. I have a lot of slop and found the spider gears on the center pin moving like a disco.
Question-- Will a carrier from any other 12 bolt be the same?
Just like others with these money pits, I am trying to save a buck when I can. I found a few at some wrecking yards for way way less then a new one and they are tight.
Thanks in advance | | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | I really don't know if this is what you're looking for, but if so...here it is: http://www.oldgmctrucks.com/page0276.html
'53 Chevy 3604 Five Window Cab ('56 235)
| | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Nope...I have already installed a rear end about a year ago and have been fighting a wobble ever since. found a couple bent wheels and the rear u-joint was bad. I took the cover off yesterday to take a look and found the spider gears riding on the center pin moving while spinning the axles.
I am looking for some help regarding swapping out the carrier of a 12-bolt not the whole rear end.
Thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You could probably get most of the slack out by replaceing the pin & gears. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | I was also thinking the pin might have a little to do with it. Just wondering if the pin could be that worn out to let the center spider gears move as much as they do.
Are talking about replacing the ring and pinion?
thanks | | | | | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | Go to Pirate4x4.com SEARCH FOR HO72 | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | a 12 bolt is a 1/2 ton rear. HO72 is a 3/4 ton rear. The lug patterns are completely different. | | |
