4 members (KEVINSKI, C10 - C90 Bill, Peggy M, JW51), 54 guests, and 2 robots.
Topics128,024
Posts1,055,390
Members48,422
#630814 03/21/2010 3:15 PM
I have a 12 bolt out of I believe a 1972 chevy truck. I have a lot of slop and found the spider gears on the center pin moving like a disco.
Question-- Will a carrier from any other 12 bolt be the same?
Just like others with these money pits, I am trying to save a buck when I can. I found a few at some wrecking yards for way way less then a new one and they are tight.
Thanks in advance
bigdog58 #630821 03/21/2010 3:34 PM
I really don't know if this is what you're looking for, but if so...here it is:
http://www.oldgmctrucks.com/page0276.html
'53 Chevy 3604 Five Window Cab ('56 235)
Nope...I have already installed a rear end about a year ago and have been fighting a wobble ever since. found a couple bent wheels and the rear u-joint was bad. I took the cover off yesterday to take a look and found the spider gears riding on the center pin moving while spinning the axles.
I am looking for some help regarding swapping out the carrier of a 12-bolt not the whole rear end.
bigdog58 #630843 03/21/2010 4:49 PM
Riding in the Passing Lane
You could probably get most of the slack out by replaceing the pin & gears.
1972 Chevy c10 Cheyenne Super
I was also thinking the pin might have a little to do with it. Just wondering if the pin could be that worn out to let the center spider gears move as much as they do.
Are talking about replacing the ring and pinion?
thanks
bigdog58 #630861 03/21/2010 6:01 PM
Go to Pirate4x4.com SEARCH FOR HO72
T-RUCK #630876 03/21/2010 7:17 PM
a 12 bolt is a 1/2 ton rear. HO72 is a 3/4 ton rear. The lug patterns are completely different.
