Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (66flea, farmallb, EchoBravoSierra, Shaffer's1950, 1 invisible), 60 guests, and 2 robots.
Topics128,010
Posts1,055,299
Members48,419
#630601 03/20/2010 11:05 PM
I need to know what is the highway speed range on a 1964 C20.(also RPM )
I have the H052 rear end and a 292 engine.
I just bought the truck and on the drive home I was doing 60 mph no problem.
I have read take they do no more than 50-55 mph. Also, I running 265/75/16 tires
Born Lucky #630631 03/21/2010 12:20 AM
You should have no problem running it at normal highway speeds but keep in mind that with the 4:57 rear end you are winding the engine up and sucking a lot of gas. I would recommend installing an overdrive in it. It will make a much better truck out of it as it will get better mileage and the engine will last longer.
Fred
rfs56trk #630643 03/21/2010 1:23 AM
what is the final drive of the stock sm465 4spd for a 292, does any one know?how about compared to a 700r4?
lucky, what tranny are you running?
rfs56trk #630647 03/21/2010 1:28 AM
RPM at 60 is 2911.
Tire width is 10.4 inches.
Tire height is 31.6 inches.
Results Table
Speed RPM
10 mph 485
20 mph 970
30 mph 1455
40 mph 1941
50 mph 2426
60 mph 2911
70 mph 3396
80 mph 3881
90 mph 4366
100 mph 4852
If your motor is in reasonable condition it should turn toward 4,000 RPM safely so your top speed is more than 80 mph.
Assuming it has a point type ignition I would not be surprised if old points start floating around 4500 limiting your top speed. I don't know the 292 well enough to speculate on its other limitations.
RPM at Speed
tyler h #630649 03/21/2010 1:30 AM
The stock 4-speed transmission in a '64 is an SM420, not an SM465.
Both however have the same final ratio, which is 1:1.
tyler h #630655 03/21/2010 1:46 AM
Born Lucky, I have a 63 C20 with the same tires, and a 4.10 HO52. At 65 mph I'm doing about 3300 rpm. Even with a 10' overhead camper I was able to push 65 and better, only passing of course.
tyler h, the final drive for the sm465 is 1:1, and any other transmission, if you don't count the over drive as "final drive". I don't remember what the over drive is for a 700R4, but in general they very from 20-30%, or 1:1.2-1.3.
Larry
I don't own a vehicle that isn't old enough to drink.
LGriffin #630793 03/21/2010 1:49 PM
Cool
So, I should feel comfortable traveling down the Highway at 60-65mph. I just do not want engine trouble. If I have to go easy I will, till I get more funds and do some mods.
Thank you all Miguel
Born Lucky #631256 03/22/2010 9:18 PM
Riding in the Passing Lane
Those 292's are tough. We used to drive them hundreds of miles wide open.
1972 Chevy c10 Cheyenne Super
