0 members (),
64
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 61 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 61 | I need to know what is the highway speed range on a 1964 C20.(also RPM ) I have the H052 rear end and a 292 engine. I just bought the truck and on the drive home I was doing 60 mph no problem. I have read take they do no more than 50-55 mph. Also, I running 265/75/16 tires | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | You should have no problem running it at normal highway speeds but keep in mind that with the 4:57 rear end you are winding the engine up and sucking a lot of gas. I would recommend installing an overdrive in it. It will make a much better truck out of it as it will get better mileage and the engine will last longer. Fred
| | | | | Joined: Oct 2009 Posts: 86 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 86 | what is the final drive of the stock sm465 4spd for a 292, does any one know?how about compared to a 700r4?
lucky, what tranny are you running? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | RPM at 60 is 2911. Tire width is 10.4 inches. Tire height is 31.6 inches. Results Table Speed RPM 10 mph 485 20 mph 970 30 mph 1455 40 mph 1941 50 mph 2426 60 mph 2911 70 mph 3396 80 mph 3881 90 mph 4366 100 mph 4852 If your motor is in reasonable condition it should turn toward 4,000 RPM safely so your top speed is more than 80 mph. Assuming it has a point type ignition I would not be surprised if old points start floating around 4500 limiting your top speed. I don't know the 292 well enough to speculate on its other limitations. RPM at Speed
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | what is the final drive of the stock sm465 4spd for a 292, does any one know?how about compared to a 700r4? The stock 4-speed transmission in a '64 is an SM420, not an SM465. Both however have the same final ratio, which is 1:1.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Born Lucky, I have a 63 C20 with the same tires, and a 4.10 HO52. At 65 mph I'm doing about 3300 rpm. Even with a 10' overhead camper I was able to push 65 and better, only passing of course.
tyler h, the final drive for the sm465 is 1:1, and any other transmission, if you don't count the over drive as "final drive". I don't remember what the over drive is for a 700R4, but in general they very from 20-30%, or 1:1.2-1.3.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Mar 2010 Posts: 61 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 61 | Cool So, I should feel comfortable traveling down the Highway at 60-65mph. I just do not want engine trouble. If I have to go easy I will, till I get more funds and do some mods. Thank you all Miguel | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Those 292's are tough. We used to drive them hundreds of miles wide open. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
