10 members (Peggy M, Youngin' Tut 59, Rick Brown, Gdads51, Hotrod Lincoln, KEVINSKI, 3800GUY, TUTS 59, classicfins, 1 invisible), 114 guests, and 1 robot.
Topics128,116
Posts1,056,589
Members48,448
after removing my valves i have found 3 of them that have some deep pitting on the top of the vale. It wont affect the way they sit but just curious if it would affect how good the engine runs.
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
Are you talking about the tip of the stem or on the face of the valve?
top of the face
how worn should the valve seats be on the valve. i have lapped mine with compound and they still have some pitting but i dont know how bad it is.
Valve seats must be almost perfect. If the seats are pitted, you need them worked at a machine shop. I still use 50+ year old valve grinding equipment which works fine but you probably find a mechanic that still has this equipment for knows how to use it.
new valves are only 70 for both intake and ex, is that cheaper than machining
Where I live, $70 for 12 valves (with proper cut on the mating-face) would be cheaper than machining 12 old valves.
New valves are cheaper than refacing the old ones. However if his valve seats are pitted, it is quite likely that the seats need working as well as the guides. Once the seats get too wide, there is no correcting them with lapping. They must either be ground with 3 different stones like I use, or cut with modern equipment. If guides are worn, they must either be replaced, knurled or sleeved.
Heres a recent link to a 292 head rebuild, mainly pictures, but it might be of some help.
http://bangshift.com/gallery/Project-Goliath-Motor-Rebuild-Update-gallery.html
thanks the pictures help, i will post some pics of the valves maybee you guys can tell
