| | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | I just spent the better half of 2 days trying to re-adjust my linkage after switching over my dual Rochesters to dual Carter W1's. The stock 235 linkage arm now appears to be too long, and will no let the Carters bottom out for a better idle. I've seen an aftermarket stainless linkage arm on e-bay this week. Is this worth the $65 they are asking? Anybody have one? Does it actually fit properly up and inbetween the manifold and exaust headers? Anybody have issues like this? suggestions? http://s537.photobucket.com/albums/...=BnSt7rBGkKGrHqIOKjIEtkoKdqeuBLi7rQO.jpg | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do not know what is at the top end of your rod, but I have used this rod with a dual-carb set-up. It bends easily and has the right diameter for connection to the bell-crank on the side of the block. | | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | yea, same top end as my rod. (1957 stock) | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | The rod should never be bent, even for clearance. If there's no other way (that's what bell-cranks are for) it has to be really thick or throttle operation will just re-bend or unbend it.
will no let the Carters bottom out? Does it over-travel (still have available motion after full throttle)? Yes: lengthen the rod. No: the rod isn't the problem, the ratio of rod travel to throttle shaft rotation is wrong.
| | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | I see no other choice for me but to bend it at the tip  . The rod is simply too long. Its not letting my carbs bottom out for idle. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I've used a bent rod of the same diameter with single and dual carbs for many decades (since I changed to a 261 in 1971).
| | | | | Joined: Jul 2008 Posts: 111 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 111 | OK guys, update: after much thought, I bent the tip of the rod to meet the linkage. Runs perfect. Hardly noticable unless you stare at it.  | | |
