3 members (MickeyP, Wally / Montana, 1 invisible), 73 guests, and 2 robots.
Topics128,050
Posts1,055,753
#62982 07/11/2006 7:24 PM
Been looking for a clutch kit for my '49 3/4 ton. All I can find so far is one at NAPA. It's advertised as 9 1/8 inch. My plan is to detach the driveline tube, jack it up, remove the 4-speed. and then remove/replace the clutch kit. I'm planning on removing and inspecting or resurfacing the flywheel too. Does all this sound about right? Any feedback on this NAPA clutch kit (#NNCM410421)?
http://www.leonmack.com/
'48 Chevy 1/2 ton
'66 Volvo 122S 2-door
'68 Volvo 220
#62983 07/11/2006 9:32 PM
Riding in the Passing Lane
Sounds good but I would not buy the clutch untill you get the old one out. There are variations in sizes. The kit generally comes with new pilot bushing & TO brg.
1972 Chevy c10 Cheyenne Super
#62984 07/12/2006 8:27 PM
Your 3/4 ton will most likly have a 11" clutch.
My Blog
#62985 07/15/2006 5:03 AM
The shop manual says remove the 2 top transmission to clutch housing capscrews and insert 2 transmission guide pins. It says that the 2 guide pins support the transmission to avoid damage to the clutch disk. Will studs work the same as guide pins? How heavy is a 4-speed transmission in a '49 3600?
'48 Chevy 1/2 ton
'68 Volvo 220
#62986 07/15/2006 1:51 PM
ODSS Lawman
ODSS Lawman
Taking long studs to support the transmission is a great tip. Those 4 speeds are HEAVY! Since you have the tranny and motor separate, now is a great time to have that flywheel resurfaced.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
#62987 07/15/2006 3:55 PM
I'm wondering how long of a stud I'll need and what size. Since I will be going to all this effort I will for sure have the flywheel resurfaced and replace many clutch-related items. Unless the rear-main seal looks like new I'll replace that too. What about transmission seals? Should I be looking into replacing any while I have this heavy puppy out?
'48 Chevy 1/2 ton
'68 Volvo 220
#62988 07/18/2006 5:40 AM
Do I need to disconnect the drive shaft at the intermediate u-joint or can I just unbolt at the trans?
'48 Chevy 1/2 ton
'68 Volvo 220
