| | | Forums66 Topics128,196 Posts1,057,390 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#62934 07/11/2006 1:40 AM | Joined: Dec 2004 Posts: 56 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 56 | I'm looking for the bracket, etc., that connected the manual throttle cable to the throttle linkage on the carbuerator. I still have the manual choke cable and all components, but I want to re-connect the original style manual throttle. | | |
#62935 07/11/2006 1:49 AM | Joined: Jun 2006 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 49 | Not sure what you mean. There is a clamp that should already be on the carby to hold the cable in place. The center wire then goes through a hole in the linkage where you probably have a cotter key now. Then a "wire stop" goes on th end of the wire. Wire stops are readily available from your local parts store or any of the online vendors. | | |
