1 members (Bucker), 144 guests, and 2 robots.
Topics128,196
Posts1,057,391
Members48,471
I'm looking for the bracket, etc., that connected the manual throttle cable to the throttle linkage on the carbuerator. I still have the manual choke cable and all components, but I want to re-connect the original style manual throttle.
Not sure what you mean. There is a clamp that should already be on the carby to hold the cable in place. The center wire then goes through a hole in the linkage where you probably have a cotter key now. Then a "wire stop" goes on th end of the wire. Wire stops are readily available from your local parts store or any of the online vendors.
